JD 345 starting issues
   / JD 345 starting issues #1
LKramer79
Beecher City, IL
JD 345
Hi all, new user. So I was mowing today and went in to fuel up my JD 345. After fueling up, I tried starting and it turned over once or twice, so I backed off the switch and tried again. On the second go round the engine temp idiot light comes on and the engine does not turn over at all, (meaning that whatever has caused the temp light to come on is preventing the engine from starting). I let it sit for over an hour, engine cool to the touch, and same issue. Has anyone seen this? Is it something on the safety side, say the switch on the brake, or is there something wrong with the temp sensor? I'd had it on/off a couple of times earlier with no issues. The mower has been running well and usually starts on the first or second turn of the switch. I double-checked all fluids when the temp light came on, but all are fine. I don't really have any electrical testing tools to test things out, nor would I know what I was really seeing. Mechanically I can usually work through things, but I'm definitely not very good with electrical, (attested by the Craftsman mower I have that I am constantly trying to find an electrical issue with, but that story is for another day!)
Thanks for any help!
   / JD 345 starting issues #2
Unless there is some funky relay I don't think the engine temp sensor would prevent starting, but could depending on the wiring system.. Most likely the problem would be related to the pto switch or clutch switch. I noticed that there is a neutral start switch also which could prevent cranking. If all that checks out then possibly the circuit board which is part of the key switch assembly.
if you decide that you need further help I am 1 3/4 mile west of Wrights Corner, and then south, just follow the signs. I'm cheaper than Sloan's
Randy
Illinois Engine.
Thanks for your help Randy. I don't really know what caused the problem because I went out the next morning and it took right off. I'm chalking it up to a fluke and if it happens again, I'll be getting in touch with you for help.
Thanks again
2020 KUBOTA RTV...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
