I have a 345 with water cooled Kawasaki. This one does not have the dreaded TDM. I can pull the float bowl and spray some carb cleaner up the main jet and it will run fine for anywhere from ten minutes to an hour then die. If I spray fuel into the air intake I can keep it running until I stop. I've replaced the fuel lines from the tank to the pump Removed the fuel cap, replaced the fuel pump and checked flow, rebuilt the carburetor, drained and cleaned the tank, and replaced the fuel filter. I'm at wits end. What have I missed?
