JD 336 baler problems
   / JD 336 baler problems #1
60sdeereman
Sigourney,Iowa
John Deere 4010
I have a 70s 336 twine tie baler. It has produced many thousands of bales in its lifetime. I was wondering if anyone would know roughly what it would cost to have it overhauled and producing bales again. I personally think that it just needs shimmed and breaks on the knotters but i do not know for sure. it might make a bale or 2 then go to tie and the break will stop the plunger. Any input is appreciated thank you.
   / JD 336 baler problems #2
Greetings and welcome. If you don't have a manual, get one from a dealer or eBay. The symptoms you describe could be caused by a number of problems: slightly out of time, plunger knife clashing with the fixed knife, needle lift/retraction linkage bent.
Since this is a gear drive knotter, the manual shows you how to check and then retime the mechanism if necessary. As far as the knives hitting, thats a plunger roller bearing problem unless one if bent. If could just be a weak or plugged plunger stop retraction spring. Empty out the machine of all hay or straw and clean out the chaff, mud, rust, and poltice. Then walk it through be hand without twine or wire in it.
I tripped the knotters and tied the 4 inch bale that was in the chamber by turning the flywheel. it tied with with no problem. nothing clunks catches, just the screech of the pick up teeth turning slowly.
2018 Toro Sand Pro Bunker Rake with Edger/Broom (A49461)
2018 Toro Sand Pro...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
