jd 3320
   / jd 3320 #1
john deere 3320
Any performance problems 3320? They tell me it will be as good as my 4300?? I have gang mowers and the new weighs 500 pounds less with narrow tires!
Any help there??
   / jd 3320 #4
The 4300 was a good tractor as well. What transmission do you have in the 4300?
   / jd 3320
HYDROSTATIC AND 4,165 HOURS ON IT WITH NO PROBLEMS! MOWS A LOT OF GRASS. I PULL 5 GANG MOWERS WITH IT AND I PRAY THE NEW ONE CAN. IT IS 500 POUNDS LIGHTER YA KNOW.
   / jd 3320 #6
Any help there??
Whether is is "as good as a 4300" would depend what you use it for. You are going down a frame size class. This may be good or bad, depending on your situation. I certainly would not expect a 3320 and a 4300 to be equivalent tractors.
   / jd 3320 #7
I think you're thinking of the new 4x20 series machines. The 4300 was sold about 10 years ago.
Power, size and weight, it is very similar to the 3320.
RICHARD SMALLSPLUMBER:
...the new weighs 500 pounds less with narrow tires!
Both the 4300 and 3320 weigh in at 2900 lbs (no loader). Where did you get that 500 lbs less weight figure?
   / jd 3320 #8
I probably was confused. I thought the 4300 was the bottom end, in the size range that includes my 4600. JD's older 4000 series models are confusing, compared with the more current progression of 1000's, 2000's, 3000's, 4000's, etc. I think I have one of the brochures on the older 4000's. I guess I'll pull it out and try to re-educate myself a bit.
   / jd 3320
I GOT THE WEIGHT OFF LINE. I AM GOING TO LOOK AT THE NEW ONE SATURDAY AND HOPE I AM NOT DISAPOINTED!!
2006 John Deere 6320 (A50120)
2006 John Deere...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
