JD 3320 W/FEL & MX5 TRAILER QUESTION
   / JD 3320 W/FEL & MX5 TRAILER QUESTION #1
mnbowhunter1960
maple lake ,mn
JD 3320 W/Imatch
hey guys I just looked at an H & H 20' tilt bed trailer 10,000lb. has anyone had experience loading with a trailer like this? or would I be better off with a trailer with ramps? only will get used aprx. 6 or 8 time a year
   / JD 3320 W/FEL & MX5 TRAILER QUESTION #2
The only reason I do not have a tilt trailer is the price. They are the cat's meow when it comes to loading and unloading! Ramps or heavy duty gates can be a royal PITA.
If you can afford the tilt model, I say GO FOR IT!:D
   / JD 3320 W/FEL & MX5 TRAILER QUESTION #3
I have a ramp trailer from Alum Line that is 20' with 5' pointed nose. It barely accommodates my rig with the MX5. The wheel hangs off the back. I prefer to have a bit longer trailer so I can alter my tongue weight by shifting the load.
   / JD 3320 W/FEL & MX5 TRAILER QUESTION #4
Hey 1960,
You describe the biggest PITA I have run into with a 20ft equipment tralier with fold-up ramps: having the bushhog on the 3 pt for travel... can't back in because of the spare tire holder, can't fold up the ramps without the bushog WAY up... just can't get the weight right with the set-up!:eek:
That leaves you wishing you had a flatbed to transport the bushhog with... truckbeds do NOT like bushhogs!:mad:
With the tilt, you can lay the bushog down anyway, or maybe back on if there is no spare in the way (?)... if you can shell it out it's definitely got my vote!:D
Frontier AP13D Pallet Forks (A50120)
Frontier AP13D...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
Two Post Car Lift (A50120)
Two Post Car Lift...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
