JD 3320 any reviews?
   / JD 3320 any reviews? #1
brandon1
I just ordered a JD 3320 ehydro with 300cx loader and 448 backhoe. Was wondering if anyone has the same equipment and could offer some reviews on performance. One of the things I'm looking to do is clear some land with it, an area maybe 300 feet by 150 feet with trees that range from 4 inches in diameter to 18 inched in diameter. After cutting down the trees I'm hoping to be able to dig out the stumps with the backhoe. Any information would be appreciated.
   / JD 3320 any reviews? #2
<font color="green"> After cutting down the trees I'm hoping to be able to dig out the stumps with the backhoe. Any information would be appreciated. </font>
When possible, I cut the roots of the tree with the backhoe, letting the weight of the tree pull the rootball out of the ground. Just don't pull the tree onto yourself... Or so I hear /forums/images/graemlins/wink.gif
   / JD 3320 any reviews? #3
</font><font color="blue" class="small">( <font color="green"> After cutting down the trees I'm hoping to be able to dig out the stumps with the backhoe. Any information would be appreciated. </font>
When possible, I cut the roots of the tree with the backhoe, letting the weight of the tree pull the rootball out of the ground. Just don't pull the tree onto yourself... Or so I hear /forums/images/graemlins/wink.gif )</font>
Hmmm, do you cut them on the near and/or uphill side first?
   / JD 3320 any reviews? #4
I have the 3720 with the same setup. I just cleared a similar size area of trees. I find it quicker and easier to push the tree over and the falling weight lifts 1/2 the roots out of the ground. I then use the loader to finish removing the tree from the ground. It all depends on what type tree. Pines are easy and I can easily push over 18" diameter pines. If I can't push the tree over I will dig some of the roots with the 448 and then push over the entire tree. Using the weight of the falling tree is a real time saver and no need for a power saw.
Hope this helps. Shooter
   / JD 3320 any reviews? #5
Brandon,
just added a post that trails on to your question.(changed the subject line a bit to try to draw specific BH users). Maybe we can raise some responses in one or both places that will help us.
   / JD 3320 any reviews? #6
I have the same equipment and love the setup. I have not done stumping yet (will be soon)- I have used the backhoe allot to dig various trenches and dry wells. I have been impressed with the size of the rocks I have been able to remove. I have dug a hole
13 ft x 12 ft to a depth of about 5.5 feet. I have moved many truckloads of stone and gravel with the loader and find it more than capable. Enjoy
   / JD 3320 any reviews? #7
Here's a pic of a 3320/300cx/447 backhoe to look at while you wait for yours to come in.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
1998 Spartan Mountain Master 40FT Class A Motorhome (A50324)
1998 Spartan...
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
