JD 3203 w 300 loader
   / JD 3203 w 300 loader #1
hotrodfeguy
Green Bya WI
3203E
I am having an issue with the down pressure on the FEL. I can put the bucket down flat on the ground. Then use the tilt and it will pick up/pull up the main boom arms. When i tilt back (IE make the buclet flat to the ground the whole boom arms go back down. I literately can go and pick up the FEL bucket by hand. The main arms do not hold it back or down.
I had a front axle seal go out as well already. Starting to think these JD tractors are junk. Worst 20K I ever spent. My tractor has about 163hrs on it!
Heavy Haul trailer (A49461)
Heavy Haul trailer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
