marshall361
I have a JD 3203 Compact Utility Tractor. The front loader works fine, no limitation on lifting. When nothing is on the rear 3 pt lift it goes up and down fairly good, but maybe not the full height. When I attach my mower or an attachment to the rear (I have an iMatch Quick Attach) it only goes up about 5 or 6 inches then stops. I does make a groaning noise when it gets up as high as it can go either with or without anything on it. I have replaced the suction filter (costly little filter) and cleaned the inline hydraulic fluid and filled up with new fluid. I undid all the hydraulic quick connects and reattached and all seemed well. I have been using loader and no issues at all with it. I did mow with it the other day in field where it was able to cut it at the 5 or 6 inch height that it will go. All works fine it just doesn't go up very far. Any advice appreciated. Also the rate of drop knob under the seat seems to work fine also. Thanks again. If you need more info let me know.
