Mowing JD 320 Problems
   / JD 320 Problems #1
Bruhn
I purchased a 320 a couple of years ago, returned the first one because of the problems I had, only to have the same with the replacement. dealer would not return the second one and basicly told me to live with it. So let me tell you how to fix some of the problems and perhaps you can help me with one I can not fix.
Vibration / belt problems: If you look between the motor and steering there is a u clamp that holds the belt from slapping. it also cuts the belt and creates a vibration. Turn it over or remove it, this fixes both issues.
My problem with the first tractor and the replacement is that it burns the lawn in spots normaly three side by side. At first I thought it was that the bearings were so hot that when stopped it burned the lawn??? Or it is leaking gas and spots the lawn during the mowing process. So far I can not fined the problem, thoughts
Hay Forks (A50515)
Hay Forks (A50515)
2023 Polaris Sportsman 570 AWD ATV (A50324)
2023 Polaris...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2017 Ford Transit 250 Cargo Van (A50323)
2017 Ford Transit...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
