JD 318 Turns over will not start
   / JD 318 Turns over will not start #1
PastorStack318
New Bedford MA
John Deere 318
I have an 87ish John Deere 318 given to me. The previous owner had its engine rebuilt 3 years ago. It was very cold out but my son (25) got the tractor going, had it running but then stopped abruptly. now will turn over but will not start, getting spark to both cylinders yet, fuel getting to carb but cylinders seem dry. have used starter fluid but no ignition.
   / JD 318 Turns over will not start #2
Does this have the Onan engine? If yes check the compression. Some of these engines had problems with spinning the cam bearings which caused the timing to jump or the valves to not open fully. Even saw some where the cam gear teeth were broken so the valves didn't move.
   / JD 318 Turns over will not start #3
Find the wiring diagram and sort out the electrical system.
Stuff like the seat safety switch, and usually the PTO switch will stop the engine from firing or sometimes from turning over. Check fuses as well. If all seems well on that front, start looking for broken wires or loose connectors.
Cheers
Trev
2015 GMC Arcadia (A50324)
2015 GMC Arcadia...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
F550 CM Trucks 11ft Utility Bed (A49461)
F550 CM Trucks...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
