No spark!! Help !! Seemed to have a run and stop issue for a little while , where the unit would just shut down, but later it will re start and run
as it should. A while back it went down and would not re start. I changed the coil and that solved the problem for a while. About 4 weeks ago it started
doing the on again off again trick, so I started replacing parts. Pulled the engine and replaced the stator, New control, 25 amp breaker, and the
condenser. Put it all back together yesterday and the **** thing will not start. Still no spark!!! I am not sure I plugged the stator into the regulator correctly
so If there is anyone here with a 318 that could post a pic of that regulator, The plug from the harness is worn and may have to be cut out and jumped, so I need to be sure where the stator wires go , and where the red lead from the harness connects to the regulator. There is an AC marking on both sides and a B+ in the middle. What am I doing wrong?? HELLLLLLLPPP!!
Wooden
Wooden
