JD 318 lawn tractor
   / JD 318 lawn tractor #1
jakew55
I have a JD 318 with a 46" mower deck. The front PTO won't engage. The light comes on when you flip the switch, and the belts are good. Any ideas?
   / JD 318 lawn tractor #2
The pto is electric. There are 2 problems I have heard of, too much space between the metal cluch plates and burned up coil/bad elec cnnection with coil. There may be more problems I am unaware of. I don't recall what the cluch plate clearence is make it as small as you can get it without touching when disengaged.
On edit: O'ya, welcome aboard.
Thanx Charlie, I'll check the coil
   / JD 318 lawn tractor #4
Check the space between the rotor and armature on your PTO. The correct gap should be .018 in. This is adjusted by turning the 3 lock nuts to obtain the correct gap. Does it engage when the tractor is cold? Most problems occur after the PTO has warmed up. Also as said your coil could be bad.
Good luck,
Ken /forums/images/graemlins/smile.gif
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A52472)
2017 GRAND DESIGN...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
