JD 310J Tank drain and Fuel Filter Change
   / JD 310J Tank drain and Fuel Filter Change #1
tassmannn
Bronze Member
Saint Marks, Fl
1985 Ford F250 6.9 IDI, 2006 Ford F250 6.0 (bulletproofed), JD 5075E, JD 994R, JD 310J (5045Ht054), Kubota RTVX 1100C, CAT D4G, 1954 Ferguson TO30, 2021 John Deere 333G High Flow
I have a 310j (4045HT054) with aprox 1200 hours on it, and recentlly drained fuel tank of about a gal of diesel to remove water and impetiments, and fuel filters both primary and final. The manual says turn key to run position for 60-90 seconds to prime system, but it didn't start, so I cracked the fule lines at the injectors and blead it that way. Started right up. Did I miss something or do I have an issue somewhere in the fuel system. It does sound like there is a pump running at the primary filter that doesn't seem to shut off.
Thx
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
