JD 310A wiring diagram
   / JD 310A wiring diagram #1
grboregon
Bend, OR
John Deere 310A
I have a 1972 JD 310 backhoe and my worker guy decided he would take the wiring out of the machine and put in new. It had a bunch of old lights, heater motor, safety lockouts so he took ALL the wires out. My question is does anyone have a simple wiring diagram for a JD or other diesel that is 12 volt and has an alternator. Not worried about accessories, just the diagram for wire to starter/solenoid, push button starter, and on off switch. Thanks
   / JD 310A wiring diagram #2
:welcome: to TBN
Not one at my fingertips, but a couple things come to mind. Maybe some ideas if you go to jdparts.com and go to wiring harness.
Also, a couple years back, another forum member had a similar request. Didn't see a diagram, but the replies may help (along with a personal message to one or more members that indicated having such a diagram).
http://www.tractorbynet.com/forums/john-deere-owning-operating/209149-i-need-jd-310a-wiring.html
Also, if you can get to a Deere dealer, they may have the tech manual to look up the diagram and make a copy for you.
Best of luck to recover the basics for start up.
   / JD 310A wiring diagram #3
If you have more questions about this 310, you might get better exposure posting it on the Construction Equipment forum.
Good luck.
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
PALLET OF PICKUP HITCHES (A50854)
PALLET OF PICKUP...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2016 LOADTRAIL GOOSENECK CAR HAULER (A50854)
2016 LOADTRAIL...
