JD 310 or other vehicles using 4239D JD Diesel Engine - Oil Pressure Sensor Location
   / JD 310 or other vehicles using 4239D JD Diesel Engine - Oil Pressure Sensor Location #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
Rebuilding a 12" wood chipper and bought a complete 4239D to replace the blown motor. Installed it and was happy to find it fired up and runs great. Don't want run it too long without temp and oil pressure gauges but unsure where the oil pressure sender should be installed. I have an engine manual but the location shown seems a bit odd as there is no oil (dry) where the mounting hole is. I assumed, maybe incorrectly, that the sender would be "wet". Hoping someone could tell me where it definitely is located. Thanks!
   / JD 310 or other vehicles using 4239D JD Diesel Engine - Oil Pressure Sensor Location #2
IIRC RH rear of engine block.
Thanks Tx Jim - You remembered correctly
2019 Chevrolet AWD Equinox SUV (A51694)
2019 Chevrolet AWD...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
Polaris ATV (A50324)
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
