JD 3038E PTO help
   / JD 3038E PTO help #1
Turbo D
Mirando City, TX
John Deere 3038E
My 3038E has about 100 hours. Hooked up my post hole auger Sunday, but could not get PTO to engage. I've used it many times before, along with my shredder with no problems. Knob engages OK, dash light turns on, but no drive action at the PTO shaft. Seat safety switch works. Tried in neutral, in gear, different RPM, but no luck. Troubleshooting guide didn't help, and have not called my dealer yet. Any ideas?
   / JD 3038E PTO help #2
Can you turn it by hand? If so I would guess that something is broken. If not, then maybe it is not getting the proper signal from the electric switch. I would let the dealer sort it out under warranty.
   / JD 3038E PTO help #3
Your PTO switch is going bad...
Mine is starting to do the same thing...
I had to smack the switch in the off and on position to get to work the other day.... gonna need a new switch.
   / JD 3038E PTO help #4
Rick
Where did you get the waving Tx flag? I like that seeing that I'm a true Texan
   / JD 3038E PTO help #5
Rick
Just steal it. It is just a .gif named possum.gif. he probably copied if from somewhere else. copy it to your desktop and it is yours forever!
   / JD 3038E PTO help #6
Rick
It has been so long I forget where I obtained it. I likely saw it and, ahem, borrowed it as kOua suggested. Feel free to copy it.
   / JD 3038E PTO help
Well, I called my dealer. Discussed what I had already checked and he said to check the solenoid wires first and if good to LIGHTLY tap on the solenoid with the engine running and switch engaged. Difficult to do without some help, since the solenoid is below the right floorboard. Note: Service tech even took a picture of the part on his screen so I knew what to look for and sent it to my phone via a text... TOO COOL! With wife in the seat, wiring all good, a few light taps on the solenoid and cycling the switch several times, the PTO came to life... YEA! New rule for me is to cycle the PTO a few times every time I'm on the tractor so the solenoid won't get stuck again. THANKS!
   / JD 3038E PTO help #9
Good to know. Thanks for the update. I'll engage my pto a little more often as well.
   / JD 3038E PTO help #10
im experiencing the same exact problem right now any chance you can post the photo on this thread of the solenoid. i looked for the solenoid where turbo d described it and could not locate it or you can text it to me if you would like 2517098264
Yetter 3415 Rotary Hoe (A49251)
Yetter 3415 Rotary...
Polaris RZR570 4WD Side-by-Side (A49251)
Polaris RZR570 4WD...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
stone rake (A49251)
stone rake (A49251)
2014 FORD F-250 (A48992)
2014 FORD F-250...
Braden Winch (A47371)
