JD 3032 E Price uotes
   / JD 3032 E Price uotes #1
kcflhrc
Veteran Member
Kansas
2013 John Deere 3032E
Got 2 quotes for JD 3032E with loader and cutter. Equipment is identical but the price is $2,300 different. Lowest quote was $16,995 with 305 loader and Frontier 60" cutter. Other quote is $19,297. Same exact equipment, both 2013 models. Now I expected some difference but WOW, $2,300 is substantial. Thoughts??
   / JD 3032 E Price uotes #2
Thoughts??? Buy the lower one?
Sent from my LGL35G using TractorByNet
   / JD 3032 E Price uotes #3
I had the same thing happen to me two weeks ago. One quote was mistaken when he put in it in under the john Deere 2520 which is being replaced by the new model. It was a $2000 difference. I ended up buying the 2520 at the lower price with no new E4 missions added to the tractor. I don't know if this maybe the same situation you have though.
Well, I called the low price dealer again and bought the tractor. I actually quizzed him on his pricing and found out why they are so much cheaper. I wont go into the details but suffice it to say it is in fact a 2013 3032E. I have his quote in hand and he is delivering the tractor Monday. I actually have both quotes in front of me and the Code for each item is identical. If it ends up being something else then he can take it home with him.
I was just looking at the quotes again and there is a slight difference in the cutter. Both are the Frontier RC2060 but the one I'm buying has the slip clutch option and the higher priced one is a shear bolt. Not sure if that's good or bad. Looks like a $143 up charge for the slip clutch. Regardless, I'm saving $2,400 and getting 0% financing.
   / JD 3032 E Price uotes #6
I'd sooner have the slip clutch.
Tractor was delivered Monday. Glad I bought the Deere, price was almost unbelievable.
   / JD 3032 E Price uotes #9
Congrats and good luck! We need pictures!
Here ya go
2007 Ford Taurus SEL Sedan (A48082)
2007 Ford Taurus...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A48081)
2016 Ford F-550...
2013 Nissan Altima Sedan (A48082)
2013 Nissan Altima...
2015 Ford Fusion S Sedan (A48082)
2015 Ford Fusion S...
(3) Bicycles (A50860)
2019 Toro Proline 32in Fixed Deck Mower (A48082)
2019 Toro Proline...
