jd 3020 won't start all of a sudden
   / jd 3020 won't start all of a sudden #1
deboer
My gas JD 3020 was running good, but yesterday when I turned the starter on it made a fairly loud thud sound, then just clicking of the solenoid. It has a front loader so access to the starter is tough. First question is: how many bolts hold the starter on, 3 or 4? I can see two ok. Could it be a sticking starter? How can I check without taking the starter off? Where to start. ken
   / jd 3020 won't start all of a sudden #2
Start with the simple stuff first. Eliminate loose or corroded electrical connections, then the battery. I never trust boost or even charges, take the battery all the way out and put in a known good unit.
Hope this helps.
   / jd 3020 won't start all of a sudden #3
When you attempt to start are you getting multiple clicks or just one? If multiple clicks, then you probably have a bad battery or bad connection. If only one click, then you might have a starter problem. There are three bolts holding the starter on. Deere makes a special wrench to access the one that is not visible.
Thanks guys. Your advice on all counts was super and I got it going again. The battery, which was good, suddenly went completerly haywire and wouldnt recharge. Thank you again.
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
TRUCKING INFO (A50774)
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
