JD 3020 hydraulic outlet flow rate?
   / JD 3020 hydraulic outlet flow rate? #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Anyone know the gpm flow rate for the hydraulic remotes on a JD 3020?
My 3020 operator's manual, amazingly and unfortunately does not include this spec. Nothing on TractorData.com either.
   / JD 3020 hydraulic outlet flow rate? #2
You don't have a flow rate for the pump that is installed? Should be the same I would think...
Nope, don't have any info on hydraulic system flow rates.
I don't own a 3020 (yet), but did buy a copy of the operator's manual on eBay.
The only specs on the hydraulics is pressure (2250 psi) and a statement that the hydraulics are used for power steering, power brakes and implement control. There're a few pages in the manual describing how to connect remote hydraulic cylinders on implements to the ports on the rear of the tractor. One of the photos shows two pairs of hydraulic ports on the 3020. But no info on hydraulic flow rates out of these rear ports. JD missed the boat on that important spec by not including it up front in the manual where the spec table is located.
   / JD 3020 hydraulic outlet flow rate? #4
The 2 wheel drive version total flow rate is 18GPM. The 4WD version total flow rate is 23GPM. They don't break it down by outlet.
Thanks for the info.
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52576)
2005 INTERNATIONAL...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
8ft Perforated Metal (A51573)
8ft Perforated...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
