Jd 3020 and 2 yd scraper
   / Jd 3020 and 2 yd scraper #1
eberlins83
Wondering if a Jd 3020 is big enough to pull a 2 yd scraper??
   / Jd 3020 and 2 yd scraper #2
Depends on what ground conditions are and what scrapper you are using. And if its a old 3020 I have seen a 5 yard on one of them.
the scraper is a John Deere 200 made by Eversman, and I belive that it is a 2-2.5 yd scraper
also have not tried it yet, thinking about purchasing the scraper, just wanted to make sure I would have enough tractor
   / Jd 3020 and 2 yd scraper #5
My FIL pulled a 3 yd "Michigan" behind an old 3020 with great success. He removed the dolly and set the tongue of the scraper directly on the draw bar to gain traction and he had a real "go get her" machine. His 3020 had wide grove tires and he was working FL sand. It was a great combination. :thumbsup:
Mike
   / Jd 3020 and 2 yd scraper #6
Is it something like this:
EVERSMAN 2SD Scrapers - Pull For Sale At MachineryTrader.com
Your tractor should do fine. If you don't have rear ballast, I would strongly suggest it. Fluid filled tires or wheel weights, or both. Without ballast, you probably will be spinning your tires a lot. That's hard on the rear end, as well as the tires.
   / Jd 3020 and 2 yd scraper #7
We used to pull a 5 yd with a JD 4630 which was rated at 160 hp. I don't think you would have any problem pulling it with a 3020. I love those old 20 series JD's. They are popular for a reason!!
David
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2004 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2004 STERLING...
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
2011 FORD F-450 (A50854)
2011 FORD F-450...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
