JD 3010D Brakes
   / JD 3010D Brakes #1
John Deere 112, John Deere 3010D
The brakes recently started grinding on my 3010D. Do I just need to replace shoes? I have several small farm jobs I need to use the machine for right now so I am reluctant to get into replacing brakes right now. I am putting myself at risk of major damage if I continue to use it in a manner where I brake as little as possible but still use them as is?
   / JD 3010D Brakes #2
If metal fines from brake disk gets into hyd system then every hyd function including frt hyd pump,steering & SCV's will need to be disassembled,cleaned and reset. If it was my tractor it would be repaired or parked. You can check for metal fines by checking trans sump screen accessed on LH side of trans located between hyd filter & rear axle housing.
   / JD 3010D Brakes #3
Are the brakes grinding or chattering. It's common for JD brakes in those years of tractors to chatter. Are you using the proper hydraulic oil?
6 Pallets of Oil / Chemicals absorbing pads (A53117)
6 Pallets of Oil /...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2015 John Deere 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 John Deere...
