JD 300X loader problem.. 3320 tractor
   / JD 300X loader problem.. 3320 tractor #1
sgtstew
I have noticed that recently, my 300X loader w/either pallet forks or buck, will "droop", in other words, either will roatate to a dump configuration. It's a slow creep, even when engine is running, and lift control is centered. The frame lift is ok, just the front end. Was disking last week, with pallet forks mounted. About every 10 minutes, I'd better roll them back or they would fall enough to catch the ground. Both bucket cylinders seem involved, in that at any given time, both cylinder rods will measure the same. So it doesnt seem to be one cylinder having a problem. What's taken place to cause this?
   / JD 300X loader problem.. 3320 tractor #2
Piston seals in the cyl are probably shot. Probably not a spool problem. Does the relief activate when cyl are fully extended?
Even if one cyl is good, the pressure from the bad cyl could leak to the other side of the piston.
   / JD 300X loader problem.. 3320 tractor #3
JD has a published spec on leak down rates-as well as other OEM's also. Some leakdown is to be expected. Yours does not sound to bad just yet, but you may want to get some seal kits to have in stock for the future.
Thanks for replies. Question now.... where's the best place to find illustrated R/R ( "remove and replace") information. I'm familiar with hyd. cyls., but I want to make sure it's done as JD has in mind.
   / JD 300X loader problem.. 3320 tractor #6
Mine will leak down when not running, but not a noticeable amount when engine is on. I use forks and a home made man lift basket to do some pruning or painting etc. If I kill the engine with a guy working from the platform, I would have to restart every 10 minutes or so to level. If I leave the engine running usually don't have to level it in the time we might be working in one spot.
Sounds like OP's is leaking a little to fast?
JB,
   / JD 300X loader problem.. 3320 tractor #7
How many hours do you have???
   / JD 300X loader problem.. 3320 tractor #8
JB,
The engine ON or OFF is irrelevant if the valve is in neutral. If the cylinder are leaking (internal bypassing I should say) then the engine running (pump pumping) has no effect if the valve is not activated.
   / JD 300X loader problem.. 3320 tractor #9
I somewhat understand your logic Kenny, but I am quite certain about my observations. Are you saying that I should not be seeing what I am ? Or that there are different types of leak down?
JB.
To "Red Horse"~~~~
My 3320 has 470 hours, probably more than half w/o front loader being used.
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2007 Chevrolet WA4500 Box Truck (A50323)
2007 Chevrolet...
2014 Ford F-550 XL (A50120)
2014 Ford F-550 XL...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
