jd 3000 4000 series loader valve
   / jd 3000 4000 series loader valve #1
pbt_sisson
stafford va
3720 john deere cab
I am looking to buy one of these machines but and disappointed in the loader operation. The valve only lets me do one function at a time? WHY? On other machines I can do two at a time. Also quick attach loader seems rather "flimsy" and not very durable./ It has alot of movements in arms. Any thoughts?
   / jd 3000 4000 series loader valve #2
I have 35 hours on a 4720 with the 400cx and a 2305 w/200cx and find the quick-tach system very, very handy. I do not find it flimsy and have gotten used to it's operation. It does operate a bit differently than my old orange tractor which had a stout, capable loader. However, I like the self-leveling feature of the 400cx. Although it seems a bit slower than my old loader, the 400cx can lift more and I like the springs located at the corner section of the loader which helps dampen and stabilize loads when driving them over uneven terrain. I lose less out of the bucket with the 400cx. Overall, I am satisfied with the JD system, but can't say it's far superior to my older loader...but far handier so far. What else are you looking at? Share some of your findings with the tractors you're trying out. Good luck.
   / jd 3000 4000 series loader valve #3
I can do multiple operations with the loaded on my 3720........ You just have to find the sweet spot...
   / jd 3000 4000 series loader valve #4
I can Blend Funtions perfectly on my 3720 Cab Tractor.... I know I wouldn't like it at all if I couldn't. But yes, mine blends functions... Up & Dump, Up & Roll Back, Up, Down & Dump, Down & Roll Back..... yep, they all work.
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
UNUSED FUTURE QUICK ATTACH PALLET FORKS (A54757)
UNUSED FUTURE...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
