JD 300 Industrial Tractor smokes when started
   / JD 300 Industrial Tractor smokes when started #1
tlfarm
1970 JD300
I have a JD300 Industrial tractor and when I start it it skips and black smoke comes out of the muffler until it warms up a little. I have put a new float and carb kit on it. I installed a shut off valve on the fuel line and as long as I shut the valve off after use it is fine. Does anyone have an idea of what is causing the problem??
   / JD 300 Industrial Tractor smokes when started #2
I am not knowledgable on john deeres, but generally speaking, Id say your float valve is leaking, which over fills the float boul and carb when the tractor sits. Floats can be a real pita. Check float height, seat and needle condition, and for contact between the float and the carb. Look for any rub marks on the float first. Sometimes I coat the float with a light film of grease and put it in and rattle it around. Then take it back apart and look for contact.
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
2013 PETERBILT 388 (A52472)
2013 PETERBILT 388...
