JD 2840 Vacuum Port ???
   / JD 2840 Vacuum Port ??? #1
wolfman96
AZ
JD
Just bought the 2840 and it has a vacuum hour meter ...
Where is the port to connect located on the block ???
THANK YOU !!!
   / JD 2840 Vacuum Port ??? #2
Never heard of such a thing. Have a picture or part number? Doesn't it have a proof meter (combo tach, speed and hours)?
   / JD 2840 Vacuum Port ??? #3
Appears there is a part no. RE17515 called a vacuum sensor noted in jdparts for the 2840.
   / JD 2840 Vacuum Port ??? #4
I believe that the 2840 had a cable driven tachometer, and was driven by the camshaft (ref p/n T20071 for a pc pic)
   / JD 2840 Vacuum Port ??? #5
Could be wrong... but I believe the sensor you are referring to is for the air filter.
thanks everybody ...
the local JD dealer said that is what it is (vacuum hour gauge) ...
it does have a mech tach which is connected and it does turn from the cam but the hour gauge is not working ...
i did find the vacuum port and it is now connected but a flat tire is keeping me from driving it at the moment ...
yes ...
   / JD 2840 Vacuum Port ??? #8
oops, your first post said hour meter... and for some reason my brain turned that into tachometer.
Well, i hooked it all back up, ran it for about 10 min and hour meter never moved ... bummer
   / JD 2840 Vacuum Port ??? #10
It's an easy fix, get a simple electrical hour meter from any parts house and wire it in to the keyed side of switch or any area you like that has juice when running.
2007 NLB Trailer Mounted Shell Side System (A53117)
2007 NLB Trailer...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
(INOP) CATERPILLAR 320 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
