JD 2640 hard to start
   / JD 2640 hard to start #1
Purdyite
Hi to all, I am a newbie here, but use other types of forums...I help my dad on his farm, I live 25 miles away. He has a JD 2640 that is driving us nuts on the starting--hard to start, barely cranks...he had the starter rebubilt some few years ago, and we just put new batteries and cables on it. Same thing. Is this a congenital defect, or can it be fixed? Is it chronic for this tractor? Has anyone suffered this and solved it? Any help is greatly appreciated.
Not sure the model year at this time...
   / JD 2640 hard to start #3
When you replaced batt cables did you relocate ground cable to engine block or starter mounting bolt? The factory location at the batt box sometimes gets rusty where batt box bolts to clutch housing causing poor connection.Also install a hyd pump destroking screw(part # AR33249 for hyd pump with no SN tag)( AR96625 hyd pump with SN tag). This helps cranking speed as it relieves hyd pump strain while trying to crank engine.
Thanks for the reply...when we re-wired the batteries, I used a separate ground cable for each battery, grounding them just below the batteries inside the batt compartment. We were using the block heater--it had been plugged in for several hours. Please tell me where the destroke screw is? I have been reading about that...
   / JD 2640 hard to start #5
The de-stroking screw will be(if installed) on LH side in frt of radiator. It points straight up and has a "t" handle on it. You have to turn it down several rounds which pushes on the stroke control valve to keep pump from building psi until it is turned back out. An alternate but not as effect is moving the steering wheel rapidly back and forth while trying to crank engine also can aid starting if a DS valve isn't installed.
   / JD 2640 hard to start #6
You need a high torque starter i had the same problem.
   / JD 2640 hard to start #7
The other thing you might have to do is replace the front half of the wiring harness...that was what finally worked on my 2640...:)
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
110 gal Sprayer Tank (A50514)
110 gal Sprayer...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
Livestock Oiler (A50515)
Livestock Oiler...
