p0peye
Bronze Member
I have seen on this forum that others have had the 2 year battery issue. Lately when I would try to start my 2520 it would act like a dead battery but would try to start. I would keep trying and once it would turn over it would start the tractor. Once it started I could use it then shut it off then restart it and would have no problem the rest of the day. Then the next morning it would be the same issue like a dead battery but after trying to start it would turn over just enough to start. The alt was fine and the tractor would charge the battery during the day. So I took the battery to my dealer and had them put a battery tester on it and check it with a load he said it was fine. I told him about my issue and he said it could be a bad cell or two no way of knowing since it is a sealed battery. I asked parts if the prorate the battery and they said if the battery has a B Guarantee it has a 3year guarantee so they did prorate it new battery 120 minus the 40 prorate so new battery 80 better than 120. Installed battery tractor started like it was new the real test is in the morning but I think it will be fine now. My tractor and battery just turned 2 years so the curse if the 2 year battery issue is alive and well still. I do feel that the sealed battery had 1 or 2 bad cells which is why it had just enough power to start the tractor barely. I hope this helps anyone with the same battery problem in the future.
Just a note I have a JD455 that has a battery that is still fine after 10 years.
How many others have had a 2 year battery issue?
