JD 2520 steering valve
   / JD 2520 steering valve #1
C-Capt
John Deere
My 2520 lost steering suddenly without any evidence of any other problems. No hydraulic leaks, levels are up, hydraulic steering rod intact, tie rod etc..
I suspect the steering valve at the base of the steering column, the steering wheel rotates either direction continuously with only minor resistance. Don’t know where else to look.
Can this valve be tested ? I’m a pretty good mechanic not by trade but just experience,
I’m trying to decide whether to undertake this valve removal myself or are special tools and expertise required. Thanks
   / JD 2520 steering valve #2
The 2520 is a compact utility, there isn’t any vertical play in the steering shaft.
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
