JD 2520 Power Beyond to Power Feed Chipper
   / JD 2520 Power Beyond to Power Feed Chipper #1
BethesdaEC
Ellicott City, MD
JD 2520
I have a JD2520 and I just purchased a Wallenstein BX42r chipper with the hydro power feed. Seems easy enough, I get a male and female connector and loop the power feed circuit through the power beyond. I talked to Wallenstein told them I had 5 GPM and a power beyond and they thought it would work no problem. I figured I probably would have to change the connectors on the chipper and there in lies the problem. TSC has the male and female connectors for the JD but they have 3/4-16 female threads and the Wallenstein hose has 1/2 NPT male. I cannot find the right adapter to connect the hose and quick connect. I did come close, I found the right thread but the 3/4-16 end is not deep enough and bottoms out on the shoulder before the flange can engage.
This project is turning into the project from ****.
I found a local hydraulic supplier who has the adapter in stock. I will pick it up at lunch and be turning trees into chips this weekend.
The part is a Parker 8-1/2 F50G-S if anybody needs the adapter in the future. The power beyond quick connect is a Parker 60 Series is a H3-62-T8.
   / JD 2520 Power Beyond to Power Feed Chipper #3
Let us know how it works.....
Regards,
Chris
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
Fire Place Mantel (A49462)
Fire Place Mantel...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
