JD 2520 comprable
   / JD 2520 comprable #1
ricko54
Rockford,MI
none
Hello,
I was looking at the JD 2520 and was wondering for comparison, what is the comparable size in the Kubota series?
Thank you
   / JD 2520 comprable #2
Hello,
Thank you
There are a lot of differences between the two tractor's specs, but based on Engine HP and PTO HP the JD 2520 is comparable to the Kubota B2620.
   / JD 2520 comprable #3
duroc is correct. I've recently compared both of them side by side, and while the HP specs are very close, the JD is a tad bigger tractor (longer, taller, heavier).
   / JD 2520 comprable
Thanks guys. Going into retirement, I'm kind of looking for my last tractor. We have two acres of which about 1 is lawn. A big garden that is a distance from the house. My only tractor is my JD 212 lawn tractor which is all of 30 years old. I was looking for something with a front bucket that I could use for moving black dirt and bark, hauling produce from the garden to the house, as well as moving some snow in the winter. Something big enough that I could put a tiller on in the spring and fall to do the garden. And a belly mower to do the lawn with. The lawn does have some trees to go around, so its not all straight cutting. There will be some maneuvering. I was thinking of a turf tire. I was considering a smaller tractor, but the thing I'm finding is that there seems to be a point when you go from a lawn tractor with small implements, to something a little more husky. I have a friend who does have a smaller Kubota with a front bucket and belly mower that he uses to cut his lawn with. He uses the bucket to move dirt, fire wood etc. I noticed that his bucket is all warped out of shape. Not that he hauls boulders in it, but it just seems to be flimsy weight steel construction. So I'm trying to get past that line where you have a yard toy, to something more respectable that can do a good days work without all the wear and tear on the tractor. Hope this description makes some kind of sense to ya! Rick
   / JD 2520 comprable #6
Those two tractors are close enough to be fraternal twins if it weren't for the paint! The green one may be a bit larger in some dimensions, but the orange one has a slight edge in some performance measurements, such as lifting capacity on the 3 point and on the loader. However I always say going just by those spec sheets is not a good way to choose a tractor for two reasons:
a) It's way more important that any tool feels and works right for its owner, even one as big as a tractor. That's a highly personal thing and what makes something preferable to one of us may be a complete turn-off for someone else. What difference does it make if one tractor lifts 100 lbs more than the other if you're struggling with controls that don't work smoothly and comfortably for you? Check out the operator station and controls, how each one runs and works; eventually your own judgement will guide you in making a choice.
b) Also, just like you don't drive your car at top speed in the real world... it wouldn't last very long if you did... you shouldn't expect to run your tractor full tilt boogie all the time either. Size your equipment so you can use it most of the time at, say 80% or less of its full capability. That goes for pto power, lifting power at either end, pulling power, etc. Your equipment will be safer and last longer and you'll have something in your back pocket for those unexpected situations. If your work ends up demanding 100% maximum performance from your tractor 100% of the time, well, you probably need a bigger tractor.
The one significant operational difference between the two tractors is the 2630 has a 3 range transmission; the 2520 has only 2 ranges. Most owners indicate that middle range is pretty handy since it allows you to stay in one range for most routine work.
The Kubota does have a slightly heavier bucket than the JD; I've not seen a flimsy bucket on any recent Kubota models.
Either make is world-class in quality and holds its value. Couldn't lose with either one, and you should also consider some the other brands also; there are many good tractors to choose from.
   / JD 2520 comprable #7
I too was looking at both those tractors, but ended up buying a New Holland T1510 because after test driving/operating it for about 45 minutes I liked how it fit me better than the others. The NH also has 3 ranges, a standard heavy duty bucket, mid-PTO as standard equip, yad, yada, yada, and it fits through my garage door w/o folding down the ROPS. I bought it at Willards Tractor in West Branch, MI. and they continue to advertise 0% financing. I'm really pleased with my choice.
Grandad4, Made some good points to consider. One of them being that there are many good tractors to choose from. Good luck with your choice, and let us know what you do buy.
   / JD 2520 comprable #8
worth its weight in gold! Every tractor should have this. I'd like to see it creep down into sub compacts yet.
   / JD 2520 comprable #10
One extra thought may be to skip out on the mmm and splurge for a ztr. You'd be surprised that the price difference isn't all that much more. I bought the jd z465 and mower about 7 acres. Much faster then the tractor, plus it keep the hours down quite a bit.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2018 CATERPILLAR...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
JOHN DEERE 310SJ BACKHOE (A51242)
JOHN DEERE 310SJ...
