JD 2350 3-pt not going all the way down
   / JD 2350 3-pt not going all the way down #1
devodad
Dowagiac, MI
JOHN DEERE
Ok guys, can anyone help me with this issue. My 3-pt on my 2350 has been working fine. I’ve been using a box blade to repair some lanes on the farm and suddenly the arms were first stuck all the way up and would only go down when the motor was turned off. As soon as I started it the lift arms would pop right back up again. Let it sit a few days and it was working again. I kept using it until yesterday, when the 6’ box blade would not go all the way down. It very slowly goes down and stops about an inch or two from the ground. The small valve on the floor between the seats does nothing. I can tighten it, which stops the lift arms altogether but when I try to loosen it it the valve just spins out. I can actually remove it and see the ballbearing down in the hole. I removed the ball (accidentally, it flew out spraying hydraulic oil everywhere when I tried to lower the arms without the valve in place) but when I put it back together it works a little better, but still extremely slow going down. Does anyone know what I can do to fix this? Thanks in advance.
ECHO PB-2520 GAS HAND HELD BLOWER (A51248)
ECHO PB-2520 GAS...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
American LaFrance Thermoplastic Striping Truck (A52377)
American LaFrance...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
