JD 2320 Safety switch won't allow to crank w/mid pro selected
   / JD 2320 Safety switch won't allow to crank w/mid pro selected #1
decarls
Brainerd, Mn
JD 2320
Hey guys, new to the forum. I purchased a used 2320 with 700 hours on it last fall. To say the least I got screwed. While tilling in the fall the rear pto stopped working...after opening it up and finding the JB Weld where the bearing used to be I took it to an actual JD mechanic. One transmission housing later and a couple thousand dollars later everything seemed fine till I put the mower deck on a couple nights ago. When the PTO selector is in either mid PTO or mid/rear PTO the tractor will not crank over. If the selector is in the rear PTO only spot it cranks fine and there's no issue. I called the mechanic that helped me get the tractor back working and he's working with me to find a solution but I thought I'd do my part to research as well.
Thanks everyone for any help you can pass my way!!
Diesel Forklift (A51691)
Diesel Forklift...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
Army Generator (A50774)
Army Generator...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2024 Doosan DX140LCR Hydraulic Excavator (A50322)
2024 Doosan...
