JD 2320 Grille Cover
   / JD 2320 Grille Cover #1
Sven_SITE
JD 2320
I found last winter while doing snow removal with my 2320 that the battery would get very cold and I would often have problems restarting the machine without jump starting it when going back out to do additional snow removal after a short amount of time. The battery is located right behind the open front grille and I was thinking maybe there is a grill cover or insulation of some type that will continue to allow air flow but shelter the battery a little bit. The property where I am doing removal is on the water and the driving wind and snow are bitter during storms. ANY IDEAS?
   / JD 2320 Grille Cover #2
maybe you could build a battery box cover just to shield the battery and not worry about blocking air from entering the grill. it might stop the wind but won't retain any heat though.
wrap the battery in some sort of insulated blanket?
   / JD 2320 Grille Cover #4
Sounds like you need a new battery to me. A "cold" battery should still start the tractor.
I think i am going to suck it up and buy another new battery again. I am kind of not impressed with the JD batteries. Any recommendations on a replacement sealed battery? anyone have a compatible model number?
   / JD 2320 Grille Cover #6
Get the group number of the battery and buy it anywhere.
JPC
   / JD 2320 Grille Cover #7
There are lots of documented problems with the JD branded batteries, just search the term "battery" and "optima" here in the JD forum!
   / JD 2320 Grille Cover #8
How about using a battery blanket? I'm using one that I bought from J.C.Whitney. It's electrical and runs off 115vac. To minimize power consumption I'm using a 115vac thermostat set to 40 degrees Fahrenheit. The battery is good but I'm giving it a fresh charge right now. I expect that the tractor would start, you do know about preheating the glow plugs don't you, even if I did not take these precautions. But I don't want to chance it.
But I agree with other poster, get a better battery. The optima brand is highly thought of in these posts. A good replacement is the model D-51R p/n 8093-167 dimensions 9.27"L x 5"W x 8.89"H
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
