justman777
Platinum Member
All, need some help here as I'm not the best with hydraulics. I've noticed for a while now my bucket cylinders (the ones that move the bucket) appear to actuate the bucket unevenly. I took the bucket off today, and sure enough, the left cylinder (from the drivers seat) actuates a tad slower than the right cylinder, which results in an uneven bucket. I measured the cylinders at one point, and the left was about one inch shorter than the right. Both cylinders appear to be on the same hydraulic lines, which "should" make them at the same pressure....and thus actuate evenly. But it doesn't. The right cylinder is noticeably and visibly faster than the left cylinder.
Any ideas? Is there something in the slow (left) cylinder that could impede the flow on both extend and retract? The FEL lift cylinders are on separate lines and aren't affected.
Thanks!
Thanks!
