JD 2305 U-Joint Grease Fittings (Lack of)
   / JD 2305 U-Joint Grease Fittings (Lack of) #1
ADin
Indiana
JD2305, 1948 B.F. Avery Model V
In recent searches on noise/vibrations on the JD 2305, I came across references to the engine to transmission U-Joint wear. Evidently some JD2305s have either 0, 1, or 2 grease fittings, none of which are mentioned in the operator manual (thanks JD). Mine appears to have no fittings, but I will double check tomorrow. Having not had to deal with any failed U-Joints in the past, what is considered normal and what would be the tale-tale signs of wear I should be looking for. I now have close to 300 hours with no additional grease, but I don't have a good feel as to whether this is significant in the grand scheme of things. The shaft is fairly straight which I assume should lower wear significantly.
Finally, how often would one recommend I lube these joints going forward, since they are kind of a pain to get to?
   / JD 2305 U-Joint Grease Fittings (Lack of) #2
Unless you submerge them under water they will likely last 20 years. A bad u-joint makes some terrible noises, grinding and banging in particular. 300 hours is insignificant.
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
