JD 2305 Power Beyod
   / JD 2305 Power Beyod #1
camoman
Ste.Anne, Manitoba
John Deere 2305
I want to be able to hookup a sickle mower to my JD 2305 and the sickle mower has a hydraulic lift for the blade. I am installing a power beyond kit (on order) and I assume I need some sort of control valve as well that would hook up to my power beyond and then supply hydraulics to my sickle mower?
I am really green when it comes to hydraulics and have been trying to read up on it but still a bit confused on terminology etc.
1st - Do I have the right concept with he power beyond and the control valve?
2nd - What kind of valve should I be purchasing? In the future I would also like to put a hydraulic top link on my 3pth as well.
Thanks!
   / JD 2305 Power Beyod #2
You need a 3 or 4 spool valve with float on one spool, and maybe detent on another spool.
You would connect the FEL PB to the IN port of the remote valve and connect the PB on the remote to the 3pt IN port/hose. OUT port goes to tank.
TractorData.com John Deere 2305 tractor information
This is a stacked valve and you can tailor it any way you want by selecting the right sections.
http://www.surpluscenter.com/item.asp?item=9SV-4-Y&catname=hydraulic
or
A 4 spool monoblock valve with one of the spools having float for the side link.
http://www.surpluscenter.com/item.asp?item=9-7864&catname=hydraulic
3 spool valve
http://www.surpluscenter.com/item.asp?item=9-6432&catname=hydraulic
New Holland 644 Round Baler (A49251)
New Holland 644...
2019 Takeuchi TL10V2 Skidsteer Loader (A49251)
2019 Takeuchi...
2012 GMC Terrain AWD SUV (A46684)
2012 GMC Terrain...
Golf Cart (A48082)
Golf Cart (A48082)
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A45678)
2018 FREIGHTLINER...
2018 John Deere 4044R MFWD Tractor (A49339)
2018 John Deere...
