JD 2305 hydraulic selective control valve lever is locked
   / JD 2305 hydraulic selective control valve lever is locked #1
KestrelMerlin
PA
John Deere 2305
Just changed the Hydraulic fluid and filter 16 hours ago. The hydrostatic transmission works normally and the 3 point hitch works fine. Power steering is fine.
The mid-mount mower deck is raised and lowered with the lever on the right side. It worked normally a few days ago, but now the lever will not move up/down or forward/back at all.
I never had to work on the this part of the hydraulic system at all. Any idea on where to look for the problem?
   / JD 2305 hydraulic selective control valve lever is locked #2
There is a lever in the center of the panel below the front of the seat. This lever locks the selective control valve. Move the lever to the other notch.
Thanks! That did it. I've never touched that lever and I forgot it was there. I have no idea as to how it was moved.
Wonderful help here from this forum!
2' Auger Extension (A50774)
2' Auger Extension...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
(9) MASTER LOCK PADLOCKS (A51243)
(9) MASTER LOCK...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
