JD 2240 and splitter
   / JD 2240 and splitter #1
magarj
I am thinking about running a firewood splitter behind my 2240. The 2240 has an AUX output at the rear and I would like to use it to run the splitter. I know the splitter has a standard detent valve that cycles the blade through the wood. Is there anything I need to do special to the AUX output to make the splitter work? There is a lever that controls the AUX output that I use to raise/lower my disk but I am not sure if it does "constant pumping" if I raise it all the way to the top?
Anybody know if it will work?
Thanks in advance!
Jeff M
   / JD 2240 and splitter #2
It should work fine, but you will probably need to bungee the handle for the remote valve AFTER the splitter is hooked up so the flow will be constant.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2003 PETERBILT 330 CARGO TRUCK (A50854)
2003 PETERBILT 330...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
