jd 2210 won't go go no more!!!!!
   / jd 2210 won't go go no more!!!!! #1
wheel
john deere 2210
it's 2004 2210 i was pushing stone for about 2 hours tractor was getting pretty warm and the pedal faded away,the tractor still moves but not very well oil in trans gets very hot, i had a u joint go bad and i tore it down replaced joint and started checking valves around pump and rearend there is about 10,check valves look ok tractor does the same slow speed forward&rev.i stopped by john deere for blueprints but they don't show the main pressure valve,i'm lost guys any advice
   / jd 2210 won't go go no more!!!!! #2
:welcome:
:D
Blueprints?
Maybe what you want is in jdparts.com where you can find the schematics and parts drawings for your tractor. Register (its free) and you will have a wealth of information at your fingertips, for your tractor and all that Deere makes.
Will help you get to the bottom of the problem. Any pics of what you meant by "pushing stone" ?
thanks ,beenthere the parts drawings i have just call out valve,don't know wicth valve, p.s i have been on jdparts they don't call out main pressure valve nether,no pic.yet but shes a little tank had a lot of problems with tires had turf tires to start with then bar tires like the news have, found deep lug bobcat tires they are same size as factor tires but side walls are 1.5 thick oh stone pile maybe 5 ton
   / jd 2210 won't go go no more!!!!! #4
You may have some serious hydrostatic tranny problems.
Best to take to the dealer or buy the tech manual for about $80 to do tranny trouble shooting.
ya,your right i guess i was hoping some one had the same trouble,and it wood be a simple fix like replacing a valve
   / jd 2210 won't go go no more!!!!! #6
wheel
For help, you might give a better description of the history of the tractor, hours of use (total and ones you put on), service done up to this point, other possible warning signs of trouble, and anything else that would help someone identify with your problem.
And pics of the stone pile..:)
i bought the tractor new it has 975 hours, i ride her hard but don't put her up wet.i change all oil&filters every 200 hours i think the book calls for 300 or 400 this mite be an overkill but just trying to make her last a life time.no warning signs petal just went soft ithink if i can figure out this valve problem i'm going to put a cooler on it
   / jd 2210 won't go go no more!!!!! #8
Hi I am having the same problem with my John Deere 2210 compact tractor!! If you get this Email Please , Please help me out and tell me what exactly you had to do!! I'm mechanically incline,but this is getting me. Mine gets very hot while bushhogging and will start getting hard to steer, pedals get hard, and a bad fluid burning smell!!
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Ford NAA Jubilee Tractor (A52128)
Ford NAA Jubilee...
2005 TerraGator 8104 (A52128)
2005 TerraGator...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
