JD 2210 Sub Compact Specs
   / JD 2210 Sub Compact Specs #1
Anonymous Poster
Epic Contributor
There are several other discussions in this forum on sub-compact utility tractors, especially the 2210, so here's a list of specs for the 2210 that is shown on Deere's website under the 'Build & Price' configurations option listed under compact tractors. The pictures that were on Deere's website are gone (only up for a few days) but they forgot to take it out of the 'Build & Price' area. Pictures are in the other discussions here.John Deere 2210 Specifications as of August 2002Subject to change without noticeENGINE:Yanmar 3 Cylinder Liquid Cooled Diesel EngineHorsepower @ 3100 RPM:Gross 23.0 (17.1 kW)*Net 22.5 (16.7 kW)*PTO 17.7 (13.2 kW) HST* *Manufacturer's Est.61.4 Cu. In. Displacement (1.0 L)Indirect Fuel InjectionAuto Bleed Fuel SystemGlow Plug Cold Starting AidAnti-FreezeDry Type Air Cleaner With Safety ElementFully Enclosed Engine and Muffler With Horizontal Exhaust5 Gallon Fuel Tank Capacity (19 L)Hand ThrottleKey Engine Shut OffTRANSMISSION:Hydrostatic Transmission:Infinitely Variable - 2 Speed Transaxle2-Pedal Foot Operated Speed and Direction ControlDifferential LockFRONT/REAR AXLE:Flanged Rear AxleSpur Gear Final Drive4WDSTEERING AND BRAKES:Hydrostatic Power SteeringWheel BrakesPark BrakeWet Disk BrakesHYDRAULICS:Open Center Hydraulic SystemHydraulic Pump - Total Flow5.5 GPM (20.7 LPM) with FilterWorking Pressure (2000 PSI)Less Selective Control ValvePTO:Hydrostatic Model: Mid PTO Standard EquipmentIndependent Mid and Rear PTO540-RPM Rear PTOHydraulic PTO ClutchPTO BrakeSeparate or Simultaneous Operation of Mid and Rear PTOFlip Up PTO ShieldROCKSHAFT, 3-PT. HITCH, AND DRAWBAR:RockshaftCategory 1, 3-Pt. Hitch Rate of Drop/Stop ValveDrawbarINSTRUMENTATION:Electric Fuel GaugeTachometer/Hour MeterOil Pressure Indicator LightCoolant Temperature LightAlternator Indicator LightFlashing Warning Light IndicatorELECTRICAL:12-Volt Electrical SystemWet Battery With 500 Cold Cranking Amps20 Amp AlternatorKey Ignition Starter With Neutral Start SwitchLIGHTS:Two Front Halogen Head LightsTwo Flashing Warning LightsOne Tail LightOPERATOR PROTECTIVE STRUCTURE:Fixed ROPS (Roll-Over Protective Structure)Deluxe Cushion Seat With Seat BeltOperator Presence SystemMISCELLANEOUS:SMV EmblemFront Weight BracketTilt-Up HoodCupholder - Left ConsoleMower Deck Height AdjustmentBASE MACHINE (4WD):Engage on the go 4WDTwo - Steel Wheels With 26x12-12 4PR (R1) Rear TiresTwo - Steel Wheels With 18x8.50-10 4PR (R1) Front TiresBase Price as of August 2002 - $10,199Availability estimated in December 2002
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2016 CAT RM300 (A50854)
2016 CAT RM300...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A49461)
2017 Mack GU713...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
