JD 2210 Rotary Cutter Suggestions
   / JD 2210 Rotary Cutter Suggestions #1
2210owner
Thinking about a 42" or 48" rotary cutter for my JD 2210. Would like some feedback on your experiences including weight issues, 3-point hitch issues etc. Considering the JD LX4, Woods RCC42 or Woods Brushbull 48 or any others.
JD 2210, 49" CX200 FEL, 54" MMM, 47" Snowblower, 54" Front Blade, IMatch.
   / JD 2210 Rotary Cutter Suggestions #2
I've never had issues with the weight of a cutter. The only 3ph issues I've had is one with the mower end of the 3ph and the side mount pins. I have a real problem with brush mowing and using the kind of pins that you slide the 3ph arms over and then latch a lynch pin through. I highly suggest a captive pin style to pevent twisting up the mower 3ph structure.
   / JD 2210 Rotary Cutter Suggestions #3
Go with the 48, you'll be glad you have the extra 6 in. and if you get in heavy tough grass, you can always take less than a full swath.
   / JD 2210 Rotary Cutter Suggestions #5
No problem with the LX4 on my 4010, which has a bunch less hp than a 2210. Weight of it hanging back there has never been a problem with a FEL. Don't know how it would be without the FEL. The 2210 and 4010 are almost identical in weight.
The 4010 will run through hood high grass with the LX4 without bogging. Only thing that kinda bogs it a bit is when the blade digs full into soft sand.
Ralph
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2012 LINDE H80 FORKLIFT (INOPERABLE) (A50854)
2012 LINDE H80...
