JD 2210 not starting
   / JD 2210 not starting #1
Gary Beaulieu
St. leonard, New Brunswick
JD 2210
Hello everyone.
My son went to use the tractor yesterday to cut the lawn. Then went to move some dirt and dig out trees.
Told me the tractor would stall when lifting something heavy. He left for lunch then came back and said it didn't start.
He checked the fuel filter, was ok, there was oil in the sight glass. When I turn the key, I hear nothing. When I move the
speed selector from low to high, I hear some clicking. The battery appears weak when I put on the lights, because they get dimmer.
We tried boosting it with a booster pak and that did nothing. Right now the sight glass is empty, maybe the lines are full.
It seems that current is being drained when I turn the key, but the starter doesn't engaqge ir even click or turn over.
I know my son can be rough with the machine because he took a heavy equipment course and worked in the woods with
a delimber but I always have to tell him it's NOT skidder, take care of it. And usually when he takes it, there's something wrong with it.
Anyway, any ideas of where to look is appreciated.
Thank you.
Tractor is 2005 with original battery but worked fine last weak when I used it with no signs of a weak battery.
   / JD 2210 not starting #3
You need to check the grounds and also make sure the battery connections are good. Mine did the same thing and I found the ground wire attached to the frame was broken. Then I found the the battery connections were broken, but I couldn't see that it was broken until I took them off.
   / JD 2210 not starting #4
This is what happens to many posters on this forum. Works fine. Shut off. Then won't turn over. Almost always winds up bad battery. Sometimes a bad ground or dirty terminals. 7 years on the battery. Replace it and clean the terminals and ground to frame connection.
   / JD 2210 not starting #6
dont for get to grease the drive shaft thru the service port by the drivers left foot - no one want to see orange parts on a green tractor
1991 International 4900 Box Truck (A51039)
1991 International...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2003 PETERBILT 379 (A50854)
2003 PETERBILT 379...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
