Grading JD 2210...Largest rear blade that will swivel?
   / JD 2210...Largest rear blade that will swivel? #1
Shawk
Platinum Member
Iowa
John Deere 3520
Would use strickly for snow removal... curious if the 5' or 6' blade will rotate all the way around without detaching?? Thanks guys!
   / JD 2210...Largest rear blade that will swivel? #2
I have a KK 6 foot that swivled ok although I think the 6 foot was a little much for my 2210.
Thank you! To much for blading snow? I won't be doing any serious dirt work with it...
Also, how heavy of a KK blade did you get? Thanks for your reply...
   / JD 2210...Largest rear blade that will swivel? #4
The KK blade I have is 6 foot. I am not sure of the weight. The tractor will lift it fine. The problem is when you are dealing with 6" or more of snow. The blade acts as a rudder and will want to turn your tractor. Since the 2210 does not have separate brakes you will be fighting keeping a straight line. I ended up trading with a neighbor that has the L3000 kubota. He had a 5 foot blade. During the winter he used my 6 foot and I used his 5 foot. The 5 foot just seemed to be a better match for the 2210.
Good to know... thank you! I'll be sure to stick with a 5' blade.
   / JD 2210...Largest rear blade that will swivel? #6
I have a 5ft RB for my 2210. I agree, when plowing heavy snow 5ft is enough. I have the FEL on and 100 pounds on each rear wheel, so traction isn't a problem, but a 6 footer would probably "overpower" the tractor in heavy going.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2015 MACK ELITE LEU 633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
