Greetings,
I'm new to this sub-compact tractor market and need advise. I have 5 acres, most of which will just need finish mowing, but I also need to plant a few dozen trees, do some minor grading and landscape work, and drag some dead trees off. I'll also have to push a little snow in the winter.
I think I've narrowed it down to the JD 2210, Kubota BX2230, or NH TZ24DA, mainly because the dealers are nearby and the machines all should probably meet my needs. One of my biggest concerns is with the limited cat 1 hitch. I'll probably get aftermarket blades/augers etc, so is this an issue?
Also, are these tractors too small to do any meaningful backhoe work? I'll probably have to do some small pond maintenance, so a backhoe might eventually be a player, but for the money, I might just rent something when the time comes.
The dealer prices are very close, and from what I've heard they all are good tractors. What are things I should be considering? Is one better than the other, or is it basically color preference?
Thanks for the input.
AKO
AKO
