JD 2210 CUT Electrical/Starter Problem?
   / JD 2210 CUT Electrical/Starter Problem? #1
ChinaSailor
Richmond, VA
JD 2210
Morning Gentlemen and Ladies.
Since 2004 I have a JD 2201 SCUT which I absolutely love and it has done everything I've wanted to do and even more.
However the other day I had the tractor up on a steep hill, parking brake on, in neutral, and idling.. everything was and has been fine..
I got onto the tractor, put the transmission in lo gear, leaned for ward a bit and took off the brake.. Tractor started moving down the hill as expected and then stopped, I think I lifted up my butt too high off the seat and the safety cut-off switch turned the tractor off.
When I tried to restart the tractor I got nothing.. I checked all the gears and levers, pto, etc etc.. made sure the brake was on, the transmission in neutral.. nothing.. however i did note that the metal seat frame was broken so I replaced that AND the seat switch.. tried starting and I just get a clicking from the starter? solenoid? Dont know.
When I turn the key into the ON position I get the right lights coming on.. but when I try to turn it over I just get the clicking...
battery went bad? loose battery cable? solenoid? starter? Any ideas gentlemen?
Like I said the machines been running fine, turns over first time every time, never had any other electrical issues.
Looking for some ideas..
Thanks in advance,
Mike
   / JD 2210 CUT Electrical/Starter Problem? #2
Your symptoms sound like a very weak battery, dirty contacts at the battery, loose battery cable clamp, or a bad ground. I'd clean and tighten connections first then throw the battery on a charger. If the connections are dirty the battery may not have been getting enough current to maintain a charge and run down over time. You could also have a problem in your charging system but start with the simple stuff.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
2011 John Deere TX Gator 4x4 Utility Cart (A49461)
2011 John Deere TX...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
