JD 2210 curtis loader blade
   / JD 2210 curtis loader blade #1
ctc1111
MA
Kubota M7040
Hey everyone, i have a JD 2210 wiht the 210 loader and 61" bucket and the front blade. I came across the Curtis loader mount blades and have been thinking that i would like to get rid of my front mounted blade and go with a curtis loader mounted blade for easier detatch and re attachment, higher lift height, and to save space in my shop were i store all of it. I notice that you can either get power angle or non power angle with the curtis blades and i'd want power angleing and i do not know how that would work considering that all the hydrolic inlets are taken up by the loader. And the mount curtis sell for JD's says for 4000 and 5000 but from my understanding the attachments from the 400 loaders work wiht the 210. So i'm just wondering if theres a way i could make this all work.
Thank you for your consideration
collin corso
   / JD 2210 curtis loader blade #2
Can't comment on the JD mounts, as mine is set up for my Kubota B2410, but what I did was to set the blade angle using the dump portion of the controller. Then disconnected and used that part of the controller for the power angle. This will work well as long as you don't have any leakdown on your dump cylinders. If you do, you will need an additional hydraulic connection for the power angle.
These blades are a bit challenging on a tractor- not like using a similar blade on a pickup. Because the mounting points are widely spaced, the blade does not float well from side to side. I found myself setting the skid shoes much higher on the left.
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
2011 WESTERN STAR 4900 SB (A50854)
2011 WESTERN STAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
