JD 2155 - YR 1990 WON'T START WITH KEY
   / JD 2155 - YR 1990 WON'T START WITH KEY #1
rcbapt
tecumseh, okla
jd4320
Took tractor apart to replace tran pump and have put back together. The tractor was starting with the key before I took it apart but won't even turn over now. Can short the terminals on starter and tractor will start. Have power out of ign. switch to relay under dash but can't get power to the starter sol. Does anyone have a wiring schematic for a 1990 JD2155
   / JD 2155 - YR 1990 WON'T START WITH KEY #2
There is a neutral start switch on the top front of three point hitch housing. Is it connected?
Yes, it was. but a young man helping undid the wires. I checked the switch with a ohm meter and it opens and closes when you shift from neutral to putting it in gear. Found the power wire that becomes hot when you turn the key to the start position. Have tried several of the other wires that were laying loose and not connected to anything but know luck. I traced the two wires form the starter sol. to a relay under the console and the wire from the ing. switch to this rely also. But not getting power out of the relay to the starter sol.
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
1272 (A50490)
1272 (A50490)
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2011 WESTERN STAR 4900 SB (A50854)
2011 WESTERN STAR...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
