3-Point Hitch JD 2140 levelling gearbox
   / JD 2140 levelling gearbox #1
Jamiecookehants
JD 2140
I have a 2140, with cab, which has a handle in the cab for adjusting the height of the right-hand link arm. This handle rotates a telescopic shaft, connected to a gearbox at the link arm end of the turnbuckle. This gearbox has completely jammed up, by the state of it the previous owner didnt believe in the use of a grease gun! Have had a good look at jdparts.com but can't find the appropriate part info.
Any help anyone can offer in finding the right part info would be brilliant!!
Jamie
   / JD 2140 levelling gearbox #2
Welcome to TBN, Jamie. Great place, good people and reasonably priced advice!
Does this resemble the identity of your problem?
John Deere - Parts Catalog
AKfish
Sadly that link just takes me to the search page. If you can tell me which page it's on that would be good!!
   / JD 2140 levelling gearbox #4
If you go to the PC # 4185(I didn't see your SN posted on this thread so I guessed on a PC) and go to part index then insert L42055 or L31648 the correct page should come up with parts schematic. These are the 2 parts with the gears made on them.
L42055 LIFT LINK, RH ADD 300.00
L31648 SHAFT ADD 32.50
That's it!! I was looking in the wrong section! Thanks alot for that. Next spare weekend I get I'll strip it down & see what the damage is like. Thanks for the help guys!!
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
