JD 2040
   / JD 2040 #1
gary_dsc
SW OH-Go Bucks
JD 3320, JD 2040, Ford 8N
I have the opportunity to buy a 1978 JD 2040 with a 48 loader. The tractor was built in Mannheim, Germany. The tractor shows 363 hours, but from its age and appearance, I think that the meter has been replaced. I can't ask the owner (since deceased), but I knew him well and he took very good care of the tractor with all maintenance done as required. The tractor has always been housed in a barn, but as with a lot of agricultural equipment, there is a lot of dirt and some rust. I can't find any dents or dings at all however. It has sat unused since the owner died (about 3.5 years ago) and of course, the batteries are dead. I know that it was running fine when last used. I have found other 2040's online, but none equipped with the 48 loader, so I'm having trouble coming up with what I should offer. The estate appraised value is 11,400, but I think that that's too much and they don't have any other offers. Anyone know anything bad about 2040s or how to establish a fair price?
Thanks.
   / JD 2040 #2
   / JD 2040 #3
Go out to Machinefinder (.com) - there are quite a few 2040's out there that are at or near the $10K mark with a few thousand hours on them. Seems like quite a bit to me, but the market is the market.
Good Luck!
Scott
   / JD 2040
Anybody know the difference between a JD 145 loader and a 48 loader? This 2040 that I'm looking at has a 48 loader.
Thanks for the replies. I'm reviewing the online sites in an effort to arrive at a fair offer amount.
   / JD 2040 #5
Info on the two loaders from my old Deere brochures:
The 48 loader dates back to the late-60s, I believe. The 145 is a newer loader which was introduced in the mid-70s. The 48 loader has a single dump cylinder while the 145 has two dump cylinders.
Lift capacity to full height is 2,400 lbs. for the 48 and 2,100 lbs. for the 145. The 145 was Deere's "short coupled" loader which means that it has a lift height that is about 1-foot lower than the 48. The short-coupled design of the 145 loader allows better manueverability in tight quarters.
   / JD 2040
Thanks for the information, EquipmentJunkie.
I bought a book about tractor prices and according to that, the tractor in average condition is worth less than 6K. I found two 48 loaders for sale online, both for 2.5K. I know the batteries need to be replaced as does the seat cushions which mice have chewed on. Not sure what other problems, but since it has sat for 3.5 years, I'm sure that oil needs changing, etc. Guess I know everything that I can know now, so I will make an offer. Thanks again for the suggestions.
   / JD 2040 #7
Both your numbers on the tractor and loader sound right to me. I agree that the appraised value is too high based on what you mentioned in your post. You are wisely doing your research. A shedded tractor with a good maintenance record is worth something, too. I'd offer what you feel is correct.
If you get the tractor and you find something that doesn't suit you about it, you can always re-sell it. If you overpaid ($11,400), you'd take a bath.
Take some pictures of the tractor, if you can. Old iron that is in good shape always warms the soul.
Best wishes to you as you pursue it.
   / JD 2040 #8
Good Good tractor , (2140 would be better with turbo )Used 100's of these in the UK ( Sound guard cabs) , with 245 loader , loader is probably older than the tractor , 30-40-50 series known for poor hydraulics ( Compared to ford or mf or ih ) and take a good look at the brakes (expensive on jd) but a tractor with a very long life we had 2 both went over 10'000 hours ,A little too much money though i dont see that being true but sometimes ? I just bought a MF 390 MFWD loader 1993 for $8000 canadian and a Ford 7600 for $6000 .
   / JD 2040
Well, I bought the 2040 including 48 loader. Now, it's time to pick it up. It's currently stored in a barn about 8 miles from my place. As I stated before, I don't believe that it has run for 3-3.5 years. I need to replace the batteries, but what all should I do to it before I drive it home? I can do some maintenance at its current location. I'm sure I should change the oil and filter, clean air filters, general check out of bolts, check tire pressures, etc. Should I drain the old fuel? I've heard that diesel goes bad after being stored for a time. How about the hydralic fluid. Should I change that too? Anything else I should do? What should be the order that I do the maintenance? Thanks again for the help.
   / JD 2040 #10
Almost 4 years I'd go ahead and drain the old fuel out, might as well change the filters too. If the oil looks good I don't know that I would change it. If you get it running I'd check the tires then drive it home. But before I got on the road I'd make sure and run that thing for 20-30 minutes to make sure it isn't go to die on you.
What id you end up buying it for? The 2040 should be a great tractor for almost any utility work.
2012 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2012 ADVANCE...
2008 KALYN BLENDER (A45333)
2008 KALYN BLENDER...
2014 KENWORTH T680 (A45046)
2014 KENWORTH T680...
YANMAR VIO35-5B (A45333)
YANMAR VIO35-5B...
2019 Ford Explorer AWD SUV (A42744)
2019 Ford Explorer...
2008 DOOSAN G25KW GENERATOR TRAILER (A45046)
2008 DOOSAN G25KW...
