JD 2040 rear end width ?
   / JD 2040 rear end width ? #1
JJBat150
Recently picked up a '79 JD 2040 that had a welded rim on one side, and a riveted rim on the other.
Currently, the rear wheels are centered OK, and are a hair over 7 wide.
I've got a 6 foot tiller that I want to run on this, but because of the 2 styles of rims, I can't see a way to get a narrower width without having each side a different distance from the centerline of the tractor.
Looking around, I found a decent deal on 2 steel rims (part # AT429861), but before I pull the trigger on these, wondering if anyone can tell me what width I can expect from using these ?
   / JD 2040 rear end width ? #2
A side difference from the centerline shouldn't hinder operation of the tractor.. but it may not let the tiller cover the tracks.
Can't help with what to expect from different rims. Good luck with that.
:welcome: to TBN
80" PIN ON BUCKET (A50459)
80" PIN ON BUCKET...
New/Unused 7 Piece Attachment Set For AGT/CFG Mini Excavator (A48837)
New/Unused 7 Piece...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2007 Detroit Diesel Series 60 14.0L 6-cylinder Diesel Engine (A48081)
2007 Detroit...
2005 International 8600 70BBL Hydro Vac Truck (A50860)
2005 International...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
